Budget (including currency): $1000-1200 USD
Country: 'MURICA
Games: Just Cause 4, Battlefront 2, those are the games I know that he plays...
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): He has a keyboard mouse and monitor already... he is looking to get a new PC because his is over 5 years old and can barely run anything... (and it's broken)
I am thinking:
PCPartPicker Part List: https://pcpartpicker.com/list/WYDTVc
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($199.99 @ B&H)
CPU Cooler: ARCTIC Freezer 34 eSports DUO CPU Cooler  ($59.99 @ Amazon)
Motherboard: ASRock B550M Pro4 Micro ATX AM4 Motherboard  ($104.99 @ Amazon)
Memory: *G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($84.99 @ Newegg)
Storage: *Silicon Power A60 512 GB M.2-2280 NVME Solid State Drive  ($52.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg)
Video Card: MSI GeForce GTX 1660 SUPER 6 GB VENTUS XS OC Video Card  ($398.05 @ Amazon)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  ($39.99 @ Newegg)
Power Supply: *Thermaltake Smart BX1 550 W 80+ Bronze Certified ATX Power Supply  ($59.78 @ Amazon)
Total: $1055.76
Generated by PCPartPicker 2021-01-22 17:43 EST-0500
Thoughts?
Good job for using Night Theme
https://linustechtips.com/topic/1297211-build-for-a-friend/
Country: 'MURICA
I am thinking:
Total: $1055.76
Thoughts?
Have patience and get a 3060 ti instead of the 1660S. The 1660S is very overpriced at $400. That's what the 3060 TI is supposed to be priced at.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1297211-build-for-a-friend/#findComment-14416538
You could ditch the cpu cooler and increase the budget by $40 and get a ryzen 5600x (with stock cooler) instead of ryzen 3600.
SPEC LIST:
  • CPU: AMD Ryzen 9 5950X w/ NZXT Kraken Z73 360mm Liquid Cooler
  • GPU: NVIDIA RTX 3090 FE
  • RAM: Corsair Vengeance LPX 32GB (4 x 8GB) 5000MHz CL18
  • Motherboard: MSI MEG X570 Godlike
  • SSD: Samsung 980 Pro PCIe 4.0 1TB (x3)
  • PSU: Corsair AX1600i
  • Case: NZXT H710
  • Monitor: Alienware AW2521H 25inch 360Hz 1ms
https://linustechtips.com/topic/1297211-build-for-a-friend/#findComment-14416551
The build looks good! I made a few changes below.
  • I switched the SSD for one with TLC NAND and DRAM cache that will perform better as an OS drive.
  • The GPU is overpriced (they all are) so the best option might be to look for a used GTX 1080 or similar. Even a 1080ti might fit in your budget.
  • I switched out the case. The one you chose is notorious for poor airflow.
  • The PSU you chose is quite low quality. The Corsair CX unit is very good, on the other hand.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1297211-build-for-a-friend/#findComment-14416552
