I got a Msi 3080 gaming x trio. And when I got it I tried running a triple a game. When I start one my cpu speed goes down base speed then after a few mins it goes down to 0.7 ghz. I have had the cpu for five months and before my 3080 I used a EVGA 1050ti. This issue occurred right as I got my GPU. After some trial and error i found out that when i uninstall my gpu driver the issue is fixed. but as soon as i re-install it the issue comes back. And help would be greatly appreciated. I thought I fixed it two days ago when I updated my bios but now the issue is back and I don't know what to do.
Specs
Case spec-omega black
Intel i9 10900kf
Asus z490 e gaming
Corsair RM 850x
XPG GAMMIX 2TB S11 NVMe
Trident z 2x8Gb 3200mhz
corsair h100i duel radiator
Hopefully people will see this
Edit: I realized that the issue came back after updating windows. Maybe Windows is the issue?
Edit 2: i found out something else i just started up far cry primal and borderlands 1 both of those don't trigger the issue. Maybe its only with online games
https://linustechtips.com/topic/1296212-i-need-help/
What did you use to uninstall your gpu driver
https://linustechtips.com/topic/1296212-i-need-help/#findComment-14409047
5 minutes ago, KingTdiGGiTTy said:
As you say it seems like a driver issue. I would try a DDU and windows updates.
If it persist I would try reinstalling windows.
I dont have any windows update although it seems as if the update came back after a windows update
https://linustechtips.com/topic/1296212-i-need-help/#findComment-14409073
10 minutes ago, Ghastlyspecter said:
I used ddu
Alright. How are temperatures on the cpu side?
https://linustechtips.com/topic/1296212-i-need-help/#findComment-14409125
3 minutes ago, Ghastlyspecter said:
They are at 55 degrees on cs:go
Damn thats so bizarre
Tried resetting CMOS?
I'd like to blame windows but I'm not so sure myself
https://linustechtips.com/topic/1296212-i-need-help/#findComment-14409137
58 minutes ago, Ghastlyspecter said:
Im not the most techy person when it comes to these things. Can you let me know what is a CMOS and how to reset it
You can turn off the system, and pull the battery out of the motherboard for about a minute
https://linustechtips.com/topic/1296212-i-need-help/#findComment-14409281
6 minutes ago, Ghastlyspecter said:
I did that and it worked. I will see if it stays for the next windows update
lol Wish you best of luck
https://linustechtips.com/topic/1296212-i-need-help/#findComment-14409464
