Lancool II Mesh vs Pure Base 500DX
Katz
Hey guys, so i wanted to change my really old hp case for a new one, i really want a mesh one and right now my 2 favorite options are either the Lian Li Lancool II Mesh or the Be Quiet Pure Base 500DX.
The thing is, i think the Lian Li is better at thermals for what i've seen, but it's a little too big and i would have no space left in my desk, also i really like that the white version of the Pure Base is entirely white because my hardware is going for a white aesthetic, but i really can't decide, any thoughts?
pure base 500Dc should have similar airflow, but it's fans are one of the quietest fans which come with cases.
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
I was in the same situation, having to choose between the 500dx and Lancool II, and eventually chose the latter because the 500dx sadly sold out everywhere in my city.
Either way I am very satisfied with the Lancool II and is probably one of my favourite cases. The only real problem I have is the amount of dust that can come inside because there is no dust filter on the front and the mesh isn't the finest. Also, if you mind it, the Lancool IIs have a hole on the top IO meant for an optional USB-C cable you have to buy extra, but I don't really mind it. Building in it was quite fun and hinged panels made it a lot easier, as well as the cable covers on the back.
I think both are very good cases, but I would personally go for the Lancool II Performance if you can.
CPU: Ryzen 5 3600Motherboard: MSI B450 Tomahawk Max GPU: ASUS Strix RX5600XT O6G ═ RAM: HyperX Fury 2x8GB 2666MHz CL16 ═ PSU: be quiet! Pure Power 11 500W ═ Cooler: be quiet! Pure Rock 2 ═ SSD: Samsung 970 Evo Plus 250GB M.2 SSD ═ HDD: Seagate Barracuda 2TB ═ Case: Lian Li Lancool II Mesh RGB
I have a Lancool II Mesh. I bought some cheap magnetic dust filters and that helped a lot with the dust. Biggest complaint with the case is the included fans. They cool well and the rgb looks good but they are not pwm so they run kinda loud.
