Hey i need your help! I'm either terrible at fancurves or my case has worse airflow than a damn Cherokee!
I have an rtx 2070 windforce oc from gigabyte , a ryzen 3600 and a b450 tomahawk max. And for cooling i have 5 deepcool (2 front and 1 top side as intake and 1 top and 1 back exhaust) rf120 fans and an arctic duo 34 cpu cooler . I've adjusted the fan curves for all the cooling product i own in bios , all taking temperature readings from the cpu and all of them with the same curve ( wouldn't call it aggressive) . I get 75+ but below 80 C on gpu and around 45 ish C (cant remember the exact number) on cpu. Cpu temps are ok i think but 75C on a 2 fan 2070 with 5 fans on the case is unacceptable!
Any advice would be great, and will guarantee a win in your next gulag!
If someone could spent 5 minutes of their time to help me figure this out it would be amazing really!!
https://linustechtips.com/topic/1294182-temperature-problems/
Looks fine for a dual fan card, case fans won't change anything to it once the card already has enough fresh air, the limit is just the card's own cooler.
F@H
GPD Win 2
https://linustechtips.com/topic/1294182-temperature-problems/#findComment-14393931
I was geting 81 degrees with 2 fans and the system was completely silent , noe i get only -6C and i have the noise of the fans ? Doenst seem right
https://linustechtips.com/topic/1294182-temperature-problems/#findComment-14393940
Well there's only so much you can gain, you have a reduced size dual fan card, it's going to run hotter than a full size 3 fan one. But it doesn't matter in the first place, it's fine running there.
F@H
GPD Win 2
https://linustechtips.com/topic/1294182-temperature-problems/#findComment-14393949
The case has a solid front or a slightlt perforated front so of course airflow is either garbage or passable at best. A fan can only pull as much through a tiny bit of ventilation.
Also a cooler is only so good and your temps are fine. If you want silence and good airflow you need to get a airflow focused case and just some good fans like arctic p series. They are silent and move a ton of air.
https://linustechtips.com/topic/1294182-temperature-problems/#findComment-14393957
Ok ok if so many people say it is ok to have those temps im good with it too
https://linustechtips.com/topic/1294182-temperature-problems/#findComment-14393973
Yea its solid in front , i am thinking of cutting it to aid airflow but that's a completely different story. Thanks for the help!
https://linustechtips.com/topic/1294182-temperature-problems/#findComment-14393980
I'd just get a cheap mesh front case and sell the one you have. A good mesh front case doesn't cost much.
https://linustechtips.com/topic/1294182-temperature-problems/#findComment-14394006
Thats an option too yea , but the market where i live is fucked up bad so thats why the first thing in my mind was diy-ing it !
https://linustechtips.com/topic/1294182-temperature-problems/#findComment-14394010
Can also look at some used ones. Like older (5+ year old) cases go for pennies and a lot of those older ones still do the fans everywhere side panel fan thing and that is about as good as it gets for cooling
https://linustechtips.com/topic/1294182-temperature-problems/#findComment-14394018
32 minutes ago, Antinomy9 said:
Koling stronghold is the name
Your temps aren't bad (at least not terrible).
Most cases with a closed of front panel has horrible airflow.
The small vents on the side of the front isn't enough to provide air to your intake fans.
A lot of manufacturers are including an extra model with a mesh front to most of their cases these days.
CPU: i9 9900K   Cooler: NH-D15   RAM: Kingston Fury 4 x 8GB 3600MHz CL17   Mobo: ASUS ROG Strix Z390-F   GPU: ASUS 3080 TUF   Case: Be Quiet! 500DX   PSU: Corsair HX850i   Storage: 250GB Samsung 970 EVO NVMe (OS), 500GB Samsung 970 EVO NVMe (Games), 2TB Crucial BX500 SSD (Storage)   Monitor: Samsung Odyssey Neo G9.
https://linustechtips.com/topic/1294182-temperature-problems/#findComment-14394025
