Hey there bud, um, what is it exactly you want help with
1 minute ago, SquiddyButler said:
Budget (including currency):
Country:
Games, programs or workloads that it will be used for:
Hey there bud, um, what exactly is it you want help with
Hi, I have everything currently except for the graphics card. So should I wait until I get that to start building or if I build it now would it not really matter/do anything to the pc.
Well unless you have integrated graphics, you won't be able to run without a graphics card..... But yeah,I'd build sooner rather than later.
What CPU do you have? If it has integrated graphics you could go ahead and use the PC before you even have your GPU. If not, I still don't think it would hurt to have it sitting assembled without a GPU
I mostly speak from my own past experience from similar problems. My solution may not work for you, but I'll always try my best to help as much as I can. If you want me to see your reply, make sure to quote my comment or mention me @WaggishOhio383, and I'll get back to you as soon as possible.
-- My PC Build --
Ryzen 7 2700x
AsRock B450 Steel Legend
XFX RX 590 Fatboy
Crucial Ballistix Tactical Tracer RGB 16GB 3200MHz
120GB Crucial BX500 SSD + 2TB Seagate Barracuda HDD
Corsair CX650M
Phanteks Eclipse P350x
I have a i9 10850k
