"Common" audio pop/snap issue, tried everything - almost?
The fix: Swallow my contempt for rear-panel 1/8" line-level jacks, go ahead and use the onboard audio, discontinue the USB junk, and humbly apologize to Messrs. Hewlett & Packard for badmouthing their product design.
Someone at the Best Buy Geek Squad informed me that these new motherboards have no "onboard audio" chipset, hence the absence of BIOS setup access. It's all done in one of the CPU cores, which in my case is a beastly AMD Ryzen 7, and it turns out that the audio capabilities are equal to or even better than any of my slightly dated USB devices. Sweet & clean output, acceptable "noise floor," and zero low-level 60Hz hum like I've always expected of devices that have no shielding between the panel jacks and the electronics.
And its input sample rate goes all the way up to 192 kHz. Holy cowabunga.
Again, to HP I proffer the most humble and groveling retraction possible, and henceforth promise not to be so hasty in judgement.
