incompatibility [SOLVED] Arctic Liquid Freezer II 360 Rev. 3 Motherboard Incompatibility (Strix X570-E Gaming)
Hello all. The problem is now SOLVED.
@narrdarr's solution is NOT NEEDED.
As I suspected the key thing here is to ALSO install the CPU, as the trick, I believe, is that instead of the cold plate applying pressure to the CPU, the actual CPU gets PULLED TO the cold plate of the Arctic LF II Rev. 3 cooler - so the whole thing works like a clamshell, I think. After tightening the thumbscrews, the backplate should press against the back of the motherboard as well.
There is also a difference between the standard and offset mounting procedure, where the standard mounting procedure covers the whole CPU, but the temperatures are actually a bit higher, which is interesting! The offset (as the name would suggest) actually leaves some of the CPU exposed (it is aprox. 90% covered with thermal paste), but your temperatures get lowered.
TO ANYONE EXPERIENCING CLEARANCE ISSUES WITH M.2 COVERS: Some AMD AM4 motherboards are unfortunately not compatible with the offset mount for Ryzen 3000/5000 series. If the mounting clips collide with components surrounding the socket area, you NEED to assemble the cooler using the STANDARD mounting method without offset. (https://support.arctic.ac/index.php?p=lf2-360r3)
SUMMARY: The Arctic Liquid Freezer II 360 Rev. 3 IS FULLY COMPATIBLE with the Asus ROG Strix X570-E Gaming motherboard.
- There is NO NEED to request rev. 2 mounting hardware (unless you'd like to)
- THERE IS ABSOLUTELY NO NEED to damage your motherboard by "modifying" (aka. ruining) your m.2 shield
- There is however EXTREMELY tight clearance between the mounting clips and caps on the left side of the board
FOLLOW THE INSTRUCTIONS.
