CPU running at under base speed while gamming...
@Saikat Mondal Most 8th Gen laptops use Speed Shift Technology automatically. The BIOS did not enable Speed Shift so press the TPL button and enable Speed Shift in ThrottleStop. Also check the Enable Speed Shift when ThrottleStop starts option.
After Speed Shift is enabled, go back to the main screen and you should see SST in green. When Speed Shift is enabled, the Set Multiplier function does not work so clear that box. Also clear the Disable Turbo box. Intel CPUs need to use Turbo Boost to reach their full rated speed.
Now that Speed Shift is enabled, you can check the Speed Shift EPP box on the main screen. Set Speed Shift EPP to 80. This is a good balanced setting so your CPU can get up to full speed when it needs to but will idle down when lightly loaded. If you want full speed all of the time, set EPP to 0. Just click on the number beside the Speed Shift EPP setting and you can set EPP to whatever you like.
The log file shows the main problem. It is constantly displaying PL1 in the far right column. This means the CPU is power limit throttling even though power consumption is only 7 Watts. Your 8250U has a 15W TDP rating so it should not be throttling at only 7W.
To try to fix this problem, check the FIVR - Disable and Lock Turbo Power Limits box. Intel CPUs use multiple sets of turbo power limits. Checking this box takes care of the secondary set of turbo power limits that some computers use. After you do these fixes, do some more gaming and run another log file. It will show if the problem is solved or if I need to recommend something else.
You can also use ThrottleStop to undervolt your CPU. In the FIVR window check the Unlock Adjustable Voltage option and set both the core and cache to an offset of -75 mV. This should be 100% stable on your 8th Gen U CPU. If you did this right, the undervolt will show up in the monitoring table at the top right of the FIVR window. You should see -0.0752 for both the core and the cache.
In the right laptop model, when all of the power limit restrictions are removed, 8th Gen U CPUs are capable of running way beyond their 15W rating. HP might not allow this level of performance. Here is how a Lenovo C930 runs.
