Is it normal for my UPS to hum/buzz?
By
elli
in Power Supplies
in Power Supplies
Solved by The_russian,
I have an APC Smart UPS 1500VA and that sounds like the self-test it does every two weeks like already mentioned. If it was a power outage it should have beeped. If it started humming/buzzing audibly for a bit then stopped, it was likely just a self test.
Featured Topics
UnRaidLegends ·
Posted in Laptops and Pre-Built Systems0 -
2
7
2
Shane Martin ·
Posted in Displays2 -
5
INotPablo ·
Posted in CPUs, Motherboards, and Memory2
