PCI Slot to USB. Is there such a thing?
1 minute ago, Master Disaster said:Well I guess I should learn to never open my mouth unless I'm sure.
Those will only work if the host has a PCIe x1 slot (they're just using USB 3.0 cables because they're convenient, not because they're signal-compatible).
32 minutes ago, TigerBoy said:It will only power an old x16 low powered custom serial interface card.
I'm not sure if you're looking for PCI or PCIe? (x16 would be PCIe, but there's basically no way you'd need x16 for a serial card...)
USB to PCI is possible (long story, but I actually just came across a part with that chip in it), but I don't think anyone has a product for it (that I've seen, anyways). Likely, you'd need custom drivers for each card (not plug-and-play).
For PCIe, you'd be better off specking laptops with Thunderbolt and getting a Thunderbolt expander (native PCIe, no adapting necessary).
