Budget (including currency): 750-850€
Country: Germany
Games, programs or workloads that it will be used for: Gaming, university stuff
Details:
AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor
Noctua NH-D15 82.5 CFM CPU Cooler
MSI B550-A PRO ATX AM4 Motherboard
Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory
Crucial MX500 2 TB 2.5" Solid State Drive --> already got this one from my old pc
Samsung 840 Evo 250 GB --> already got this one from my old pc
Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive
MSI GeForce RTX 2060 SUPER 8 GB VENTUS Video Card --> already got this one from my old pc
Fractal Design Define R6 USB-C ATX Mid Tower Case --> already got this one
be quiet! System Power 9 600 W 80+ Bronze Certified ATX Power Supply --> already got this one from my old pc
I'll uprade from an Intel i7-4790 @ 3.60 Ghz and 16 GB of DDR3 ram.
The main goal is to get futureproof for the next years of gaming in 144hz.
Give me every tip/critics you got. It is much appreciated.
Thank you all,
Mo
https://linustechtips.com/topic/1290857-my-first-build/
Haven't checked but make sure you PSU has enough wattage. Overall looks good, but others may have critiques. :)
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1290857-my-first-build/#findComment-14370045
if im being optimistic, an rtx 2060 super draws enough for 550w-600w psus.
Make sure to quote me if you want me to respond
Turn your Mobile VR or PSVR Headset into a working 6DoF SteamVR one guide/tutorial (below):
My PC
https://linustechtips.com/topic/1290857-my-first-build/#findComment-14370049
Country: Germany
Details:
Thank you all,
Mo
Cooler is a bit overkill for a 5600x, but it will still do the job well.
Looks fine overall.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1290857-my-first-build/#findComment-14370060
600w is plenty.. (speaking from experience, own a 2060 super and ryzen 5 2600 and runs fine with a 500w psu)
https://linustechtips.com/topic/1290857-my-first-build/#findComment-14370152
don't use ddr3 because it won't work at modern aaa games. try ddr4. it givess massive performance boost
other than that no problem.
Country: Germany
Details:
Thank you all,
Mo
Pls Mark a solution as a solution, would be really helpful.
BTW pls correct me, iam really stoobid at times.
https://linustechtips.com/topic/1290857-my-first-build/#findComment-14372696
Apparently the 10700k goes for less price in Germany as compared to 5600x. In your case, I will go with the 10700k.
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1290857-my-first-build/#findComment-14372823
its really good!
                         Dream build:
Intel Core i5-10600K | GIGABYTE Z490 AORUS ELITE | Cooler Master MasterLiquid ML240L| RGB Corsair Vengeance RGB Pro  16GB (2x8) CL18 3600MHz |
Intel 660P 512GB NVMe | Kingston A400 SSDNow 480GB 2.5" | WD "Caviar" Blue 1TB 7200RPM 3.5" | MSI GeForce RTX 2060 Super Gaming EVGA SuperNOVA 750 G+ | THERMALTAKE RGB H200 USB 3.0 |
Peripherals:
Keyboard: Corsair K65 RGB Rapidfire
Mouse: Corsair Harpoon RGB Pro
Monitors:
(1) LG 27'" 27Gl650F-B 144hz 1ms IPS G-Sync Pivot 3
(2) Acer Predator XB241YUbmiprz 23.8" 144Hz 1ms G-Sync
Headset:
Kingston HyperX HX-HSCSC2-BK-WW Cloud Stinger Core
https://linustechtips.com/topic/1290857-my-first-build/#findComment-14372880
You can't swap DDR3 and DDR4 RAM, the sockets on the motherboard are totally different.
CPU's only support 1 type of RAM, with all AM4 CPU's, that's DDR4. With FM2 CPU's that's DDR3
Please tag me @RTX 3090 so I can see your reply
https://linustechtips.com/topic/1290857-my-first-build/#findComment-14373341
Im switching from ddr3 to ddr4 so no worries. But thank you anyway
https://linustechtips.com/topic/1290857-my-first-build/#findComment-14379595
yeah i know that i was going to tell him to switch motherboard and cpu but i got sleepy so i went to sleep
https://linustechtips.com/topic/1290857-my-first-build/#findComment-14380325
Country: Germany
Details:
Thank you all,
Mo
Everything looks great, but if you might have any rendering or photo/video editing for school you might want to bump yourself up to 8-cores. 3700x would do a great job for this. or even a 10700k (nice intel mobos go for dirt cheap compared to amd these days). Mind you, do that only if you are going to be putting the workloads i just listed on it.
https://linustechtips.com/topic/1290857-my-first-build/#findComment-14380467
I just do the usual Excel, Word and PowerPont stuff. I'm a economics master, so I do not do fancy video editing stuff. But thank you for your advice
https://linustechtips.com/topic/1290857-my-first-build/#findComment-14388218
I'm not planning to do so. Im buying completly new MoBo, Ram and CPU. Just the SSD, GPU and PSU are already build in my current PC.
https://linustechtips.com/topic/1290857-my-first-build/#findComment-14388228
Parts list looks good, weather or not you can get a 5600 is another story 😂
https://linustechtips.com/topic/1290857-my-first-build/#findComment-14388274
