Help on undervolting
Go to solution Solved by WereCatf,
1 minute ago, ninja ride123 said:
b360
You need a Z-series mobo for over-/underclocking and/or over-/undervolting.
2 minutes ago, ninja ride123 said:
no i mean can you help me about the overrheating problem?
It showing some high temperature for less than half a second doesn't mean anything, especially since there is literally no way it'd magically be able to then drop 40C in less than half a second! No, that just seems like a glitch.
https://linustechtips.com/topic/1290843-help-on-undervolting/#findComment-14369970
wow thank you and last  question! When i am playing i have 70 -80c but sometimes is spiking for 1 sec to 85 maybe 89 but comes down in less of a sec back to 70 is it a glitch too?
https://linustechtips.com/topic/1290843-help-on-undervolting/#findComment-14369981
70C-80C is still fine and a very brief spike to 85 or 89 isn't something I'd care about. Still, if you're worried, look into buying a beefier cooler.
https://linustechtips.com/topic/1290843-help-on-undervolting/#findComment-14369986
