look , idk if this exists or can exist , i just want to know if it ban or cant be done
i want a program which acts like a Virtual  monitor , a window that i can minimize , and than i want to plug my laptop , so i have my laptop inside this Virtual monitor , maybe a PlayStation , maybe an apple tv .
https://linustechtips.com/topic/1290635-my-vision/
I think what you're looking for is Picture by picture (something called picture in picture, PiP, PBP, etc.) in a monitor. That allows you to have another input on your screen.
https://linustechtips.com/topic/1290635-my-vision/#findComment-14368536
i know but , i don't have that in my monitor , i was wondering if i can switch on of my hdmi ports on my gpu to be input instead of output and have a virtual tv/monitor which i can use
https://linustechtips.com/topic/1290635-my-vision/#findComment-14368578
Unless you have a hardware level double tuner in you TV I do not knot of a way to accomplish this.
The only other way would be to run it in a virtual machine then you can drag the window around ETC.... But that would require separate hardware also.
I think there used to be TV tuner cards with an input port that could do this. But you would have to search.... I think last time I saw one was like 2010?
Basically you want a capture card with HDMI in some exist. USB 3 connection to PC and a HDMI input on the device.
Then you either use the software that comes with the card or DisplayFusion to create a separate monitor.
https://linustechtips.com/topic/1290635-my-vision/#findComment-14370141
