Hey guys I’m Planing (and I bought some of the smaller bits and pieces) on doing a Rackmount gaming server over the summer that sits in my basement and I connect too from 3 floors up with This super cool device. I need 5 120mm fans for This rackmount case. Sound doesn’t matter because it’s far far away from me, Id like the most powerful fans possible for Overcooking headroom on the new amd 5 processor I plan to use and buy once it gets back in stock. I’ll be using the Noctua NH-D15 for my cpu cooler because it’s one of the things I already bought :). Help me out guys!
https://linustechtips.com/topic/1290062-best-for-a-rackmount-case/
8 minutes ago, ScriptKiddo said:
Oh crap! I screwed up the title! Oh well :/
You can click on the title to change it.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
Delta would be my manufacturer of choice for maximum air flow fans when noise isn't a concern. However if you have the budget you might prefer to go with the Noctua NF-F12 industrialPPC 3000RPM fans. They're Static Pressure fans.
Something you have to be wary of is your CPU cooler height. Server chassis aren't built for most enthusiast CPU tower coolers. The NH-D15 won't fit in a 4U chassis.
