What is wrong with my pc?
Solved by DailyProcrastinator,
Well a memory issue likely means there is an issue with your RAM. Download and run MemTest86, see what you results are. If it reports an issue this will pinpoint that your physical RAM modules are causing your problems. If that is the case check and see what warranty that memory has, often memory has 5-10 year or limited lifetime warranty. If it is still covered begin the RMA process.
