Posted December 31, 2020 I need a new mouse because my g502 and im torn between the g703 and g pro but I don't think the pro is worth the extra considering they are so similar. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 31, 2020 I use the G502 lightspeed myself, and I wouldn't switch to any of the ones on your list, but that's because I actually use all the buttons. I need more buttons, but Logitech doesn't make the mouse I used to use anymore. If you're including them as options though then you probably don't use everything on the G502. Regardless, if you've been using the G502 and have been happy with it keep using it. It's an excellent mouse. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 31, 2020 Author 33 minutes ago, Drexl said: I use the G502 lightspeed myself, and I wouldn't switch to any of the ones on your list, but that's because I actually use all the buttons. I need more buttons, but Logitech doesn't make the mouse I used to use anymore. If you're including them as options though then you probably don't use everything on the G502. Regardless, if you've been using the G502 and have been happy with it keep using it. It's an excellent mouse. i don't use all the buttons know Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 31, 2020 I have the 603 (703 w/o RGB and uses AA's) and love it. I put two Lithium AA's in it over a year ago, and it's still got one bar's worth of battery life according to G Hub Work Rigs - 2015 15" MBP | 2019 15" MBP | 2021 16" M1 Max MBP | Lenovo ThinkPad T490 | AMD Ryzen 9 5900X | MSI B550 Gaming Plus | 64GB G.SKILL 3200 CL16 4x8GB | AMD Reference RX 6800 | WD Black SN750 1TB NVMe | Corsair RM750 | Corsair H115i RGB Pro XT | Corsair 4000D | Dell S2721DGF | Fun Rig - AMD Ryzen 5 5600X | MSI B550 Tomahawk | 32GB G.SKILL 3600 CL16 4x8GB | AMD Reference 6800XT | Creative Sound Blaster Z | WD Black SN850 500GB NVMe | WD Black SN750 2TB NVMe | WD Blue 1TB SATA SSD | Corsair RM850x | Corsair H100i RGB Pro XT | Corsair 4000D | LG 27GP850 | Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 1, 2021 What's your hand size and grip style. Also, what are you primarily using the mouse for? CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32 Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
