Anyone know where I can get that RVZ01 PSU cable or should I just solder and heat shrink some other PSU cable together with another one? I think the latter is much more convenient.
Rig Specs:
Ryzen 7 1700 3.9ghz @1.33125v Cinebench Scores Best:1750cb Average: 1735cb
Asrock X370 SLI/AC  SOLD
Evga GTX 560 Ti 1gb    Just got a EVGA GTX 780 HydroCopper
G.Skill Ripjaws V 2x8gb 2400mhz oc’d to 2666mhz (bought when ram was still cheap :()
Corsair RM850
Enthoo Pro M Acrylic Changing to a Inwin 301 soon
Custom CPU Loop (watercooling is boring to me right now so I want to go back to air cooling and do like one more WC Loop in a Inwin 301)
Intel 256gb SSD
Kingston 240gb SSD
HyperX 90gb SSD
Not So Shitbox v3 Specs:
I7 2600k oc'd to 4.7 @ 1.4ish (will do more when I get a better cooler)
MSI P67-GD55  Sold to fund my gpu
Gigabyte Windforce HD 6950
Team Elite Plus 8gb DDR3 (1 stick) @ 1600mhz
Thermaltake Toughpower 750 watt
Cooler Master T4
Enthoo Luxe
Kingston 120gb SSD
WD Black 1tb HDD
Laptop:
Asus GL552VW-DH71
i7 6700HQ
2x8gb DDR4
1tb hard drive
GTX 960m
15in IPS 1080p display
https://linustechtips.com/topic/1287353-3-prong-cable/
Thats a standard 3 prong for PSUs lol those are like a few dollars at most.
Chicago Bears fan, Bear Down
https://linustechtips.com/topic/1287353-3-prong-cable/#findComment-14343713
I mean the cable with the chassis mount. I want the special nice looking one lol. Not something I can just jerry rig (which I will)
Rig Specs:
Corsair RM850
Intel 256gb SSD
Kingston 240gb SSD
HyperX 90gb SSD
Cooler Master T4
Enthoo Luxe
Kingston 120gb SSD
WD Black 1tb HDD
Laptop:
Asus GL552VW-DH71
i7 6700HQ
2x8gb DDR4
1tb hard drive
GTX 960m
https://linustechtips.com/topic/1287353-3-prong-cable/#findComment-14343925
What do you mean chassis mount? If you mean the actual PSU connector on the case, I don't understand why you exactly would want that.
https://linustechtips.com/topic/1287353-3-prong-cable/#findComment-14343966
Cables plug into recepticals. Your pictures show recepticals. If you want a cable that plugs into such recepticals at one end and plug into a power outlet at the other, you will have to tell us what country you are in. Or at least what type of power outlet you use.
https://linustechtips.com/topic/1287353-3-prong-cable/#findComment-14343967
My bad I mean the cable as a whole. I'm in the USA. I have a different plan for this build now anyways haha.
Rig Specs:
Corsair RM850
Intel 256gb SSD
Kingston 240gb SSD
HyperX 90gb SSD
Cooler Master T4
Enthoo Luxe
Kingston 120gb SSD
WD Black 1tb HDD
Laptop:
Asus GL552VW-DH71
i7 6700HQ
2x8gb DDR4
1tb hard drive
GTX 960m
https://linustechtips.com/topic/1287353-3-prong-cable/#findComment-14348142
Standard US 3 prong "Type B" cable. I have no idea what you're talking about.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1287353-3-prong-cable/#findComment-14348312
A US 3 Prong Cable that can chassis mount to a case. Just like in the RVZ01 with two phillips heads screws. and the routed through the case to an alternate spot for where the PSU is really mounted. Now to save cost I am probably just going to use a bigger PSU and use a block off plate and have a little cut out for where the PSU will really be mounted. This ITX build is in a small sleeper HP Case with just one 240mm radiator. I'll take pictures in a bit and probably format and rename this thread. I'm repurposing an old cooler master case for honeycomb grills, 2.5 inch hard drive bay, single slot PCI-E and basically jb welding, sanding, cutting, painting some stuff. It's going to have a semi-modular thermaltake 750w psu, Ryzen 1700,32gb of ram, and A R9 Fury X because that's really all I need for editing and whatever this computer will do. A couple nights ago, I just cut out a few rivets and pieces of metal with some nippers, but today my dremel stuff is coming in. None of the stuff is mounted yet. I'll be using some red XSPC coolant I think, random 16/12mm hard fittings, PETG. Nothing is secured in right now besides the motherboard and I have some fittings and routing to still plan.
Build will be:
AB350N ITX Mobo
https://www.bykski.us/products/bykski-mini-ddc-pump-reservoir-combo-w-armor-silver-b-tank-ddc-mi
https://modmymods.com/darkside-dual-lp240-extra-slim-radiator-ds-0377.html or a XSPC EX240
Some Crucial 32gb 16gbx2 kit 3200mhz
R9 Fury X (kept stock)
Two Corsair ML120's
4 SSDs (570gb altogether)
1tb WD Black
HGST 7K4000
(both HDDs are in some USB3.0 dock)
Thermaltake PETG tubing
Ryzen 7 1700 (kept stock)
XSPC EC6 Blood Red (1000ml)
hp_pavilion_slimline_series_1578900642_d91d8dffb_progressive.jfif
r9furyx.jfif
Rig Specs:
Corsair RM850
Intel 256gb SSD
Kingston 240gb SSD
HyperX 90gb SSD
Cooler Master T4
Enthoo Luxe
Kingston 120gb SSD
WD Black 1tb HDD
Laptop:
Asus GL552VW-DH71
i7 6700HQ
2x8gb DDR4
1tb hard drive
GTX 960m
https://linustechtips.com/topic/1287353-3-prong-cable/#findComment-14348961
https://linustechtips.com/topic/1287353-3-prong-cable/#findComment-14349366
19 hours ago, brob said:
After a 3 minute youtube video in IEC plugs and some googling, it seems that some people have similiar ideas too lol
IEC320 C14 to C13 Extension Cord C14 with Screw Holes and C13 Short 60cm Lenght. availables https://www.amazon.com/dp/B083CSBSRV/ref=cm_sw_r_cp_api_glc_fabc_BY07Fb0G2P2Q4
The wait time is a bit long so I think I’ll stick to the ATX size psu even though it might turn out to be a bit cramped. Hoping for no leaks and good temps! Might even run both 240mm rads in tandem and see how they test despite the limited ventilation.
Rig Specs:
Corsair RM850
Intel 256gb SSD
Kingston 240gb SSD
HyperX 90gb SSD
Cooler Master T4
Enthoo Luxe
Kingston 120gb SSD
WD Black 1tb HDD
Laptop:
Asus GL552VW-DH71
i7 6700HQ
2x8gb DDR4
1tb hard drive
GTX 960m
https://linustechtips.com/topic/1287353-3-prong-cable/#findComment-14351412
Good find on the part.
https://linustechtips.com/topic/1287353-3-prong-cable/#findComment-14351868
