I'm getting mixed reviews. Can a 970 chipset overclock? Like at all?
I know I toyed with my 8350 and couldn't get a stable 4.4GHz on stock voltage, using a 970 Extreme4, but a recent thread has peaked my curiosity with a user being able to achieve a mild overclock on an 8320 with an M5A97.
Is it possible? Is it smart?
if you have to insist you think for yourself, i'm not going to believe you.
https://linustechtips.com/topic/128711-overclocking-and-a-970-chipset/
Yes, you can oc on the 970 chipset.
Is it smart? *shrug*
The Extreme4 has a terrible VRM design. I wouldn't advise overclocking much at all with that board. The 970 chipset is more than capable of overclocking, I have a Gigabyte 970 board and I overclocked my 6350 to 5GHz. The Asus M5A97 isn't much better than your Extreme4. The only 970 board that I could recommend for overclocking an 8 core would be the GA-970A-UD3(P).
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
