6 minutes ago, MrStealYoMs said:
Is this normal? I've sent from a cv650 from corsair but had to rma, and now I have my old kolink 80 bronze 600 watt and it's making a buzzing noise.. I have ordered a 750 watt antec to PSU that is rated gold, this issue will stop tho right?
My specs are 1060 3gb r5 3600xt 16gb 3600mhz ram b450 f STRIX mb 480gb SSD and 4 rgb fans that are powered by 4 pin molex
https://linustechtips.com/topic/1285917-psu-buzzing-noise/#findComment-14334198
It sounds like coil whine. It's most common on GPUs (though can happen on PSUs), so I would make sure that its coming from the PSU and not from the GPU. Even if it is coming from the GPU, a bad PSU can cause a GPU to whine, so run the new unit to see if it goes away. If you make sure that it is coming from the PSU, a new one should fix it, and if it doesn't, get a UPS to act as a power cleaner. Also check that the new PSU is highly rated on the PSU tier list.
https://linustechtips.com/topic/1285917-psu-buzzing-noise/#findComment-14334208
Noise can come from HDD if one use that and it beings to fail, PSU, GPU, if not you are hearing a fan noise (but I guess not).
higher rated PSU can give maybe a cleaner output, so it might help a little but not really sure.
Else it can be the GPU like said above.
Like this:
https://linustechtips.com/topic/1285917-psu-buzzing-noise/#findComment-14334235
Like this:
Ok i saw if i could make sure it is the psu but it turns out its both but the psu is way more and the gpu coil whine is wayyyyyy less noticable
https://linustechtips.com/topic/1285917-psu-buzzing-noise/#findComment-14334300
