Corsair H100i Platinum AIO temperature spikes
Solved by Applefreak,
21 minutes ago, Knecko said:I have the Corsair icue 4000x RGB
Small temp spikes are not uncommon. Your case has a big sheet of glass in front of the radiator, limiting airflow. You can try mounting the radiator up top instead and see if it changes anything. If you do not have fans exhausting there, you should add at least one. Also make sure the pump is running full speed. I would generally expect lower temps while idling unless your room temperature is closer to 30C in which case those temps are expected.
