Asus Tuf 3080 from Newegg wasn't sealed. - need advice
solris
last week i managed to grab one of the 3080s from newegg.ca  As the title says there was no seal on the opening tab, and on top of that it seemed to be ripped a little bit. Testing it is kind of difficult as my current pc isn't up to date and will suffer from some pretty big bottlenecks.  I should be able to just call Newegg and get it replaced, but the fear of the wait scares me.  If anyone has any thoughts or advice please let me know.  Thanks
i would contact Newegg immediately. Let them know the seal to your card was broken - don't forget top mention that it was a 3080 too. I would rather wait another week or two and get a new card with no defects. Also, make sure that you did NOT purchase a refurbished version.
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
Just test it out. Check for marks on the PCB, dust build-up etc. I am not that anal when it comes to situations like this one. If card works and has no issues along with a valid warranty I'll use it. I might contact the seller and ask for a coupon or few dollars back but I wouldn't be mad if I didn't get any.
