AryI have G49 Odyssey been playing everything using the hdmi cable supplied all has been fine I had to go up to the attic to get Christmas stuff for the misses. (pain lol) I seen the box of the monitor so I said frig it I'll get the DP cable outta the box cause I always seen linas using dp cables and he's says there better.So I've hooked it up fired up a game all on same ultra settings I never changed anything and jesus it's bad grainy/glitchy/teary picture. Have I done something wrong is it a bad cable at this rate I'm giving up on it any help would be greatful thanks in advance.
https://linustechtips.com/topic/1283084-poor-graphics-from-display-port/
If it works fine with HDMI either your display port cable is dead or the monitor display port is dead. Buy a new cable and see if not the port is dead.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
No.
F@H
GPD Win 2
Yes.
throw it away dp sucks, doesn't even have a license... they only put it in cause it's royalty free, otherwise there would be no "dp".
36 minutes ago, Kilrah said:
No.
Well, I disagree!
-Scott Manley, 2021
