Build
PCPartPicker Part List: https://pcpartpicker.com/list/gsyCdD
CPU: AMD Ryzen 3 3100 3.6 GHz Quad-Core Processor
Motherboard: ASRock B450M PRO4 Micro ATX AM4 Motherboard  ($64.99 @ Newegg)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($63.49 @ Newegg)
Video Card: Asus GeForce GTX 1650 SUPER 4 GB TUF GAMING OC Video Card  ($424.99 @ Amazon)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  ($44.99 @ Amazon)
Power Supply: SeaSonic S12III 550 W 80+ Bronze Certified ATX Power Supply  ($46.98 @ Newegg)
Total: $645.44
Generated by PCPartPicker 2020-12-18 16:49 EST-0500
So I just relized that my case only has one case fan included so I need some fans. I already have the case so..... ya. Do you have any recomendations on what fans I should use in this build. Question can you intermix fans, for example use the one case fan and two other fans?  Also how many fans do I need?
https://linustechtips.com/topic/1282894-fan-recomendation/
Congratulations on making the end of your signature true.
I'd go with arctic fans for budget.
As far as intermixing fans, you're fine to. The only thing to keep in mind is PWM(4 wire) vs non PWM(3 wire). Your motherboard will still be able to control non PWM fans, but headers and all that won't work together. 3 pin non PWM on a 4 pin splitter if you're going that route.
Edit: You don't have 3 pin headers on that mobo. Make sure they're 4 pin fans.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1282894-fan-recomendation/#findComment-14314870
I am confused, do I need to get some kind of adapter for this to work with the Artic F12 fans?
https://linustechtips.com/topic/1282894-fan-recomendation/#findComment-14314878
No, they're PWM. Sorry. I over complicated this. Brain fart.
Edit: I'm having a hard time wording stuff right now.
No, you won't need an adapter. They're PWM.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1282894-fan-recomendation/#findComment-14314881
be quiet! Pure Wings 2
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
https://linustechtips.com/topic/1282894-fan-recomendation/#findComment-14314886
18 minutes ago, zhnu said:
If you're going budget go with artic fans unbeatable at their price point.
https://www.arctic.de/en/products/cooling/case-fans/
19 minutes ago, Bouncewasp said:
Arctic F12 are great airflow case fans and cheap too? Also if just add that the MSI mortar is generally considered one of the best matx board and is a similar price to the asrock board you've listed.
I forgot to quote in the last reply so quoteing here.
How should I configure the fans in my case and how many should I have in total?
https://linustechtips.com/topic/1282894-fan-recomendation/#findComment-14314896
Realistically, I think you could get away with 2 on the front. That case looks like it's not bad for airflow.
If you went with the value pack, you could do the 2 front. 1 bottom as intake to help the GPU, 1 on the front top to help the others, then swap the one on the rear for matching fans.
If a case is laid out well, you don't need that many fans. In my ITX case, I have 2 noctuas. There's the one on my PSU, 3 on my GPU and then my cpu cooler is a 240 AIO with 2 fans on it and that's enough for my pc.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1282894-fan-recomendation/#findComment-14314909
Arctic F12 PWM are the best bang for the buck.
For those specs I recommend 2 front intake and 1 back exhaust.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/1282894-fan-recomendation/#findComment-14314926
