New build help!
Solved by Nena Trinity,
Just now, Memesnspleens said:Thank for your help Nena!
ugh would of been amazing if AMD had a decent DLSS alternative and good ray tracing!
Their ray-tracing is good, the issue is not all games are yet to support their tech since it needs to be updated for it. DLSS IMHO I would never use in any competitive gave like ever its far to blurry and since it uses AI to predict what is there to fake the native resolution I most say it might do mistakes especially with hair and fast moving objects, but AMD are working on some new tech but if its a DLSS clone or not I am not sure...
