Recently, I started to stream and saw that my cpu was running at 77-80C under stock cooler. I also tried to overclock my CPU but couldn't too long because the temps were in the low 60's while idle and 80+ while gaming.
I saw review saying the be quiet Dark Rock slim (black) was a good choice (85$ CAN). But, I also saw that the Dark Rock 4 was cheaper than usual at (100$ CAN).
Do you think the 15$ is worth it even if I have a 3600?
https://linustechtips.com/topic/1280282-cooling-ryzen-5-3600/
I would suggest that you cinebench r20 back to back a couple. This will fully load the cpu. If temps stay under 90c then technical your ok. If you still want a cooler.
Id probably choose the DR4 over the DRs. But there are some other great choices too. Like:
Fuma 2
Freezer esport 33/34
Mugen 5
With any cooler you'll want to make sure it fit your case.
https://linustechtips.com/topic/1280282-cooling-ryzen-5-3600/#findComment-14295684
  • 2 weeks later...
