Will my headset pickup sound from Cherry MX Blue
if interconnectability with your mouse software and all in one device are big bonuses for you, that kind of ends it. FWIW, the K95 isnt a bad board at all. I quite like how robust corsair stuff is too. I just personally find a much more natural workflow with a couple dedicated devices (which if you move that way would allow you to look into others in the k line that may have better stock) such as a gaming keypad + 70% keyboard.
Now back onto the topic of this forum though, if you are set on the k95 and need to get blues (they are nice switches tbf), henreys recs are the way to go. Get the mic as far from the keyboard as possible, try out RTX voice, try not typing *as* hard and if you do, maybe try o-rings, but your options past that are kind limited.
