PC light tube
Go to solution Solved by Kilrah,
That trend has passed, you won't really find that anymore unless you can get your hands on some old stock.
F@H
GPD Win 2
https://linustechtips.com/topic/1279525-pc-light-tube/#findComment-14290113
You can apparently find some if you sarch for PC case CCFL tube.
https://www.amazon.com/12-Cold-Cathode-Case-Lights/dp/B000BUDHOA
It was all the rage at some point but that was about 15 years ago, basically 2005's RGB :P
F@H
GPD Win 2
https://linustechtips.com/topic/1279525-pc-light-tube/#findComment-14290125
You are awesome thx :D
Well i think i Like 2005's RGB
https://linustechtips.com/topic/1279525-pc-light-tube/#findComment-14290144
