So I recently decided to liquid cool my 3900xt and after getting an nzxt kraken73 and installing it. Under any sort of load, even gaming, my cpu jumps right up to 110*. I've remounted it several times, tried chasing air bubbles out of the pump, and applied Kryonaut thermal paste to no avail. Any thoughts?
https://linustechtips.com/topic/1279055-ryzen-9-3900xt-cooling-issues/
We’re you getting these high temp problems before you went to a big cooler?  The throttle temp of ryzen2 is below 110° so something is up.
I had a smaller liquid cooler on before and was having the same problem. At idle currently my cpu is at 59* and my liquid is 29*. Seems like those should be closer together...
“Max turbo”?  The 110°c thing still doesn’t make sense to me.  My memory is throttle temp on ryzen2 is lower than that.
IDK what to call it, before I update the bios the cpu was pegged at 4.4 GHZ now its sitting around 4-4.2 unless I hit it with something, temp under full load ar still not right but i'm ont sure what else to try.
“Boosting” I think.
the issue is basically all modern CPUs are designed to temp throttle before they can damage themselves.  This number is commonly pretty high lately. Like 95c for many intel chips.  I’m having trouble finding the throttle temp for a 3900xt.  110c seems high to me though.  I vaguely remember throttle temperature for ryzen2 to be 100°c which struck me as really quite high.  If a chip can go above its throttle temp there’s something wrong with it. I don’t know that it has though. This is an xt chip not an x chip.
4 hours ago, Bombastinator said:
“Boosting” I think.
So one of my friends pointed out that maybe my motherboard is sending more voltage than it should. I have an MSI meg godlike and its got this built in overclock dial that was on, but upon closer inspection it only works for the lower end cpus 2700x etc... To elaborate I had it on but the cpu was not boosting to higher than its advertised 4.4 Ghz. So I wonder if it wasn't giving it too much juice and causing the overheat. Thoughts?
