Sketchy Power Supply
Go to solution Solved by WhitetailAni,
Get a new one that isn't as crappy, then play with the old one on your driveway and see if you can get it to blow up.
I recently pulled out my old power supply and installed it into a new system and turn it on and it makes this horrible screeching sound like a old CRT TV it also makes another sound static discharge around 20 minutes in with the power supply on I might just buy a new power supply I don't want to risk frying old components.
Oh yes forgot to mention it doesn't seem like the over current protection doesn't seem to work on the Power Supply.
https://linustechtips.com/topic/1278476-sketchy-power-supply/
You are taking a risk there...better to get rid.
https://linustechtips.com/topic/1278476-sketchy-power-supply/#findComment-14282260
