How do you fix underperforming components?
Go to solution Solved by JJwow5555,
I factory reset my pc and its better now way more smoother. I probably had to reinstall windows.
Well apart from making sure everything is up to date, you can try to DDU your display drivers and install fresh ones. Just don't let Windows install the driver automatically after you remove the current one.
Also a factory reset never hurt anybody.
One way to make a computer feel like new is to do a clean windows install from a USB stick
This will get rid of junkwares and stuff you no longer need
Pretty much brings your computer back to its full potential, if it's still lack luster for your needs then you'll probably need an upgrade
-sigh- feeling like I'm being too negative lately
