I'm trying to make a plex server on a dinosaur computer. To be specific, i5 650 4gb ram, optiplex 950. I installed a 4tb drives with bunch of movies on it. But it is not to be detected, it doesn't show up in the disk management and file explorer. Does anyone know the possible issue.
https://linustechtips.com/topic/1277637-hard-drive-not-being-detected/
Is it detected in BIOS? [EDIT] as a 4tb drive.
CPU - Ryzen 7 5800x3D |  GPU - RTX 3080 TUF OC | Motherboard - ASUS TUF X570 | RAM - Patriot Viper Blackout 32GB 3200MHz | Case - InWin 805 | Boot Drive - Corsair MP600 PCIe 4.0  Storage - 2 x 1TB SSD's & 1 500GB SSD | PSU - Seasonic Focus Gold 1000w | Display - ASUS TUF VG27WQ Curved 1440P 165Hz | Cooling - ASUS TUF LC240 AIO + 5 aRGB Fans
Assuming a SATA HDD.
Any of:
  • OS Problems
  • Disabled sata port
  • Bad sata cable
  • Bad sata power connection
  • Bad drive
  • Bad motherboard
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
11 hours ago, Moonzy said:
Does it support the file format?
That said I've had issues with old boards having loose sata ports
11 hours ago, svmlegacy said:
I rolled that into "bad motherboard". You can't replace a sata port on one.
Got it solved. Unplugged it, and back in. It seemed to work. Thanks
