hello, I don't know if this is the right forum.
one day i wake up to play valorant games on my gaming laptop
specs: i7-7700hq
           gtx 1050ti
           16gb ram
i opened valorant and my fps is dropping suddenly, i went and checked the temps and noticed that my cpu's temp is 98-100, it was definitely throttling, i was surprised because this doesn't happen unless i have my "extreme cooling" option off, my laptop has extreme cooling option where it runs the fans at a high speed to keep it cool while gaming. Moreover, i go and try to find the solution, so after 5 hours i figure out that it was a bios update that i did the night before, the bios update was causing this problem! after i did a flashback my cpu temps got back to normal.
MY QUESTION IS, DID WHAT HAPPED AFFECT MY CPU LIFE SPAN OR AFFECT IT NEGATIVLY?? SINCE I ONLY HAD IT FOR HOURS AND THROUGHOUT THESE HOURS I WOULD RESTART THE LAPTOP SEVERAL TIMES TO TRY MY FIXES, DO SHORT TERM HIGH TEMPS AFFECT THE CPU OR ONLY LONG TERM ONES??
MY LAPTOP'S NAME IS: LENOVO Y520
(((PLZ REPLY ASAP)))
https://linustechtips.com/topic/1277236-cpu-overheating-question/
It's probably fine. The cpu should shutdown if it reaches 100c to prevent damage.
It'll be ok, some laptop manufacturers don't even bother with cooling and let cpus run at 100C under load as a design.
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
58 minutes ago, ragnarok0273 said:
I have replied.
I'm going to guess and say that the BIOS had a weird fan curve thing going on, and that the update fixed it.
elephants
na, actually when i updated the bios to the newer version i had the problem
Whenever I update a BIOS (at least on a desktop, haven't had an issue with an HP laptop BIOS update), it normally resets the BIOS to default configurations and you are unable to use the previous saved BIOS profile due to it being on a older revision. Was it even possible you just needed to clear CMOS on the newer revision?
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
i actually searched and found that many had the same issue as me..... some even provided the old bios update to fix it
If other users are reporting this issue, then it can be an issue the manufacturer has to fix and remove the update from the public.
8 minutes ago, flixZ said:
i am just scared that what happened will affect my CPU in the long run? will it though?
No, it won't at all if it was at that those temperatures for a couple of hours. By the time that would affect the CPU (a marginally low chance of any problems), you would already be on a newer laptop. The electrical engineers that put a T junction of 100 C for that CPU did that for a reason and there are many other protections built in to reduce clock speeds (thermal throttle) and also shut down the system to prevent it from running until the temperature issue is resolved.
I found this on the Lenovo website someone answered a person who was asking should he update his bios on the Lenovo y520.
~Snipped photo from above~
Yeah that seems to be buggy BIOS revisions Lenovo is pushing out...
