Hard drive issue
Go to solution Solved by Electronics Wizardy,
Try formatting the disk in disk management.
https://www.windowscentral.com/how-format-new-hard-drive-windows-10
Just create a partition by doing like so.
Right click Windows icon at the start menu, select disk management, locate the drive with unallocated space and right click on the unallocated area. Make new partition and boom, you're set!
https://linustechtips.com/topic/1276093-hard-drive-issue/#findComment-14264400
19 minutes ago, Chionele said:
You need to format and create a partition via Disk Management first.
Thanks for the help I was able to partition the drive in about 5 mins.
https://linustechtips.com/topic/1276093-hard-drive-issue/#findComment-14264433
