PC making "drilling like" sound
Fatty
12 minutes ago, Fatty said:
My PC is making this weird noise, https://vocaroo.com/1ljTnJwN2Zf6
I can't identify which component is making it.
is my HDD failing?
download crystal disk and check the hdd health. It more sounds like a fan tho
Any Help is appricated! Please correct me if I´m wrong!
Sorry for grammer/spelling mistakes, but english is not my native language (it´s german in case you were curious) *expand to see builds*
Primary PC: CPU: AMD Ryzen 5 3600 | GPU: Crossfire Radeon 6870 + 6850 | RAM: CORSAIR Vengeance 2X16 = 32GB @ 3600MHZ DDR4 | MOBO: ASUS ROG STRIX B450-F | COOLER: COOLER MASTER ML360R | CASE: DEEPCOOL Matrexx 55 V3 ADD-RGB | PSU: GIGABYTE P850GM 80+ GOLD | SDD: CRUCIAL MX500 250GB |
Everything thats not colourful I haven't bought yet.
Secondary PC(Currently not operational): CPU:  INTEL Q8200S @ 2.33Ghz | GPU: GTX 750 ti / 760 | RAM: 4X2 = 8GB @ 800MHZ DDR2 OCZ Platinum | MOBO: ASUS P5E-VM SE | COOLER: Be Quiet! Silent Loop 280* | CASE: DEEPCOOL Matrexx 55 V3 ADD-RGB* | PSU: CORSAIR RM850 2019 80+ GOLD* | SSD: CRUCIAL MX500 250GB*
Everything marked with * is what I bought for the Primary PC and I'm just using it until I get all the parts.
anything i can do?
Just now, Fatty said:
anything i can do?
Try pluging your fans one by one out and check for noise if, there is still a sound when no fans are connected, I would plug the hdd out and boot like that if its gone than than its more likely the hdd and i would safe the data aslong its still possible
