Umm...what? Please read your posts before you post them.
That motherboard supports M.2 SSDs so I'm not sure what the problem is.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1275661-need-help/#findComment-14261430
Just now, Dishonored said:
There are 2 type of m.2 port one is SATA and one is NVMe both are different right?
They're different yes but your motherboard says it supports SATA.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/1275661-need-help/#findComment-14261441
12 minutes ago, Dishonored said:
Brought an Samsung 860 Evo SATA M.2 but my motherboard support NVMe seller don't take refund so any adapter my motherboard model number is gigabyte B360M D3H
The manual for your motherboard says it supports both SATA and NMVe, so I'm not sure what the problem is.
https://linustechtips.com/topic/1275661-need-help/#findComment-14261447
from the webpage:
https://www.gigabyte.com/Motherboard/B360M-D3H-rev-10#kf
Quote
  • Ultra-Fast M.2 with PCIe Gen3 X4 & SATA interface
also, make sure to use the quote button so that people can see your responses. otherwise we won't get a notificaion.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1275661-need-help/#findComment-14261462
