Well i built a PC for a friend that is kinda ... loaded.
Specs are: R5 5600x, RTX 3070 16gb Ram @3200mhz, 1TB nvme, 750 PSU, NZXT H510 elite case, x570 mobo
                  LG 27GL850 monitor, Logitech K380 keyboard, Logitech MX anywhere 3 mouse, Razer Krakenheadset, logitech C922 camera
My point is that i was glad at the beggining because i was about to build my first PC and it was for really quality hardware and peripherals.
Almost all of them are better than mine.
To be fare i m absolutely happy with mine, and i ll upgrade in 6 months or whenever 3000 series GPU can be bought.
I expected to be thrilled and glad but i m accualy tired :D
I googled all the extra stupid f*cking hatefull RGB cables that gladly were only to put more RGB if you want
I got anxious because it wasn't for me
I downloaded about 250GB of games and software
I troubleshot many win10 problems (even on instalation)
I toggled some BIOS things
i changed appearances to match the taste of the future owner
Logged in 1024 places that you put your email and create accounts
Updated hardware and shit
Stress tested GPU, CPU and shit
All worked all good
Overall. I wasn't happy while doin it, it lasted for hours, the overall resaults was astonishing
And i can't wait to do this again somehow :D
How was your first build?
https://linustechtips.com/topic/1275536-pc-build-done-thoughts/
I did this once and it was when my PC was hitting the 8 years old mark. Upgrading had not crossed my mind until I built a brand spanking new system for a friend.
Needless to say I upgraded 2 months after I built his lol.
As for his specs, he has a very solid balance build where I wouldn't say anything is "over the top" nor is it budget. Just a really great system that will last him years to come.
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    BenQ MOBIUZ EX2710Q 27"
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
https://linustechtips.com/topic/1275536-pc-build-done-thoughts/#findComment-14260301
* thread locked *
We already have lots of these threads, and even a section reserved for that ;
https://linustechtips.com/topic/1024053-post-your-battle-stations-and-build-setups/
https://linustechtips.com/forum/3-build-logs/
And a section to help for building ;
https://linustechtips.com/forum/18-new-builds-and-planning/
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/1275536-pc-build-done-thoughts/#findComment-14260311
Guest
