Search In
  • More options...
Find results that contain...
Find results in...
Post Your Battle Stations and Build Setups!
Word2022
 Share
http://img248.imageshack.us/img248/1943/cam00011c.jpg
amd phemon x4 955 overclocked to 4ghz
gigiabite ga-ma770t-ud3p
corsair h60
aero cool shark 120mm case fans
hd 6950 1gb
corsair cx 600 psu
kingston 4 gb ddr3 ram
boot drive 320gb hdd
808 gb hdd for games
amd fx 6300  @4.4ghz @1.4/ga-970a-ud3/HD78702gb /antec 620w psu
@Skitz, to be honest with you, you are using the wrong fan for H60. The Aerocool Shark fan has a really high CFM but poor static pressure which isn't good. I use my Aerocool fan as rear exhaust because of the high CFM since it can easily push a lot of hot air out. You should buy yourself a Noctua F12 or Silverstone AP120 fan which would improve the temperatures.
Wow , grab a dust cleaner , i would have gotten you one for xmas . Its bad for your system . ?
EDIT 2019: How is this still getting notifications LOL. 6 year old post, it's not even quoting the post it was referencing anymore after 2-3 forum software upgrades.
thanks for tip
http://img248.imageshack.us/img248/1943/cam00011c.jpg amd phemon x4 955 overclocked to 4ghz gigiabite ga-ma770t-ud3p corsair h60 aero cool shark 120mm case fans hd 6950 1gb corsair cx 600 psu kingston 4 gb ddr3 ram boot drive 320gb hdd 808 gb hdd for games
You need some better screws going into the radiator, you dont want a leak in there
AAAAAAAAAGGGGGGGHHHHH!!!!
i know but they were the only i had and i will go and get some soon
and something like this http://www.msy.com.au/product.jsp?productId=1311
Why can't I upload? It keeps saying 'Error Uploading Image'
Image is either probably larger than 600x600 or 100000 (kb?) size.
Tantō
  • Case: NZXT Switch 810
  • Operating System: Windows 10 Professional
  • Motherboard: ASUS Sabertooth Z77
  • Central Processing Unit: Intel Ivy Bridge i7-3770K
  • Random-Access Memory: Corsair Vengeance 4x8 GB DDR3 1866 MHz
  • Graphics Processing Unit: Aorus GeForce 1080 Ti
  • Power Supply Unit: Corsair Professional Series AX750
  • Cooling: NZXT Kraken X52
  • Storage: AData S599 60GB + AData SU650 500GB + WDC Blue 1TB +AData SU800 1TB
  • Keyboard: CoolerMaster Masterkeys Pro S
  • Mouse: Corsair Scimitar Pro RGB + CoolerMaster Master RGB Hard Gaming Mousepad
  • Audio: Logitech 2.5 Speakers + Feenix Aria + Bose In-Ears
  • Monitors: 2x Acer Predator XB271HU
  • Thread Link
Shuko
  • Device Model: Samsung S20+
  • Operating System: Android 10
  • Read-Only Memory: One UI  2.1
  • Kernel: Stock
http://linustechtips.com/main/topic/1264-overclocking-guides/'>My Intel Ivy Bridge Overclocking Guide
They would work but for a few more dollars, you should get the F12.
http://msy.com.au/product.jsp?productId=8654
you think i should just use the aerocool fan for the back of the rad and use the Noctua NF-F12-PWM 120mm 1500rpm PWM Focused Flow Fan for the front of the rad what that be good
i7 3820
660 ti POWER EDITION before the revision
32 gigs of dem rams in quad channel at 1600 mhzzzz
corsair 830 ssd 128 gigs
corsair hx 850 watt psu
intel liquid cooling solution
fractal R4
(upgrades to come)
G9X is in the mail along with the G710+
another SSD
later down the road another 660 ti
the new kraken X60
beast sound card
I think my build looks good. all black sleeving EHRMEGERD CORDGASM
 Share
