G.Skill Ripjaws B-die OR Hynix for Ryzen 5 5600X and Gigabyte B550 Aorus Pro motherboard?
Solved by Letgomyleghoe.,
I said it many times and said it again only pay the premium for b die kits if you overclock ram. If you xmp and forget the kits will preform the same. Most kits will work just fine even if they aren't listed in the qvl so I would get the hynix kit as it will preform and I can't stress this enough the same exact as a b die kit unless you manually overclock your ram.
