How to connect ps4 to vga monitor
GELMEL
is is possible to connect my ps4 to my old vga monitor without an hdmi switch
1 minute ago, Arika S said:
sure, just get a VGA to HDMI adapter. you'll need to figure out how to split the audio off though.
i have an adapter but i doesn't work idk why , audio is not an issue i can use headsets
Amazon.com: Moread HDMI to VGA, Gold-Plated HDMI to VGA Adapter (Male to  Female) for Computer, Desktop, Laptop, PC, Monitor, Projector, HDTV,  Chromebook, Raspberry Pi, Roku, Xbox and More - Black: Computers &
do you have a way to test to make sure the adapter and VGA cable work? ie another device with HDMI out?
idk why but starting with nvidia's 20-series, my HDMI to VGA active adapter stopped working, even though it would work on 900 and 10 series gpu
maybe it's something to do with HDMI versions?
-sigh- feeling like I'm being too negative lately
yes it works well i use it to use my vga monitor as a second monitor
20201125_111029.jpg?width=1194&height=671
mine is new adapter bought is recently from a local computer store works well so far
can you verify what HDMI version is PS4 and your PC?
i have a suspicion that whatever chip the HDMI to VGA converter uses, it's incompatible with the newer HDMI standards, though i might be wrong
There are cheap hdmi to vga with audio port.
Converter Hdmi To Vga Audio - Kabel Hdmi - Vga Line Out - Konverter HDMI to  VGA with Audio | Shopee Indonesia
i am sorry idk how to do that is there a way to check?
have it already
ps4 is HDMI 1.4, idk what gpu u got, but HDMI1.4 is pretty old and should work
dont think it's this, since 1070 and 2070 have the same HDMI version (2.0b) and my adapter works on one but not the other, hmm
image.png.3ea9d0c43c07dbdc5d8017c0024f34a4.pngis this image helpful i hope 😅
