Converting wired headset to wireless?
So I have a logitech g pro headset and it is currently wired but It has a removable 3.5mm audio cable that it uses to transmit audio so i was wondering if I could switch that out with a Bluetooth transmitter and have a receiver on my pc to receive the microphone and be able to send back audio to the headphones since it is a headset after all. The reason why i think this might be difficult is because im not sure what to look for and if theres something that can transmit mic audio and headphone audio at the same time  Any and all help is appreciated and I can provide more details if needed,Thanks!
https://linustechtips.com/topic/1271541-converting-wired-headset-to-wireless/
On top of having a wireless receiver for the audio, you also need something that will give the headset the power normally transmitted through the headphone jack.
