Hello. Brand new member here but watched hours and hours of LTT videos. A few of those being on PSUs. The MSI PSUbeing brand new there hasn't been many suggestions on if its worth taking a chance on.
This build im doing is my first ever full PC build and I've decided to do a full MSI build. I'd like to include the MSI PCU but being its their first venture into that market I was curious if its a good idea or if I should stick with a brand thats been around longer. Thanks guys!
https://linustechtips.com/topic/1271316-msi-power-supply/
You should wait for proper revies of the MSI psus before buying them.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1271316-msi-power-supply/#findComment-14229058
Thats kinda where I'm at. I'm not anywhere near technologically gifted to be able to read power consumption numbers and core temp readouts. I can't put stuff together like a boss but maybe I'll wait and hopefully see some more reviews then and upgrade that piece later. Still gotta find that darn MSI chair now haha. Thank you for the suggestion.
https://linustechtips.com/topic/1271316-msi-power-supply/#findComment-14229081
Welcome to the forum!
There is no real reason to just buy a MSI PSU unless it clearly is a good quality unit. This said there really is no info yet on these so I would wait, or just get something else. And in almost every (modern) case the PSU is covered by the shroud, so blind brand loyalty would matter even less with a PSU.
Just to provide some more info, a PSU's efficiency rating is not in direct correlation with how well it is made or the quality of the components used. There are plenty of sh!t 80+ Gold and Platinum PSUs out there. Some bad apples barely (or do not) even meet the efficiency rating they are rated at.
The efficiency rating of a PSU is simply a rating for how well the PSU converts the AC power it receives from the outlet to DC power for the systems hardware. So, for simplicities sake, lets say your system draws 100w of power. If you have a PSU that is 80% efficient, it will draw 125W from the wall.
I recommend looking at this list:
I generally recommend no less than Tier B, but if you have an upper tier GPU and a decently powerful CPU just go Tier A, there are plenty of options that are good quality and realiveitly inexpensive. Cheaping out on a PSU is not worth it, even something like voltage ripple can kill hardware while the PSU itself can continue to run without issue.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/1271316-msi-power-supply/#findComment-14229096
I wouldn't go a all 1 brand PC, tends to cost more for less performance.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/1271316-msi-power-supply/#findComment-14229104
I understand the appeal of one brand PC, but ultimately it's a limitation that will make your computer worse. I don't know much about MSI's PSUs, but I'm willing to bet it's gonna be a rebranded/reskinned unit from an actual PSU company, with an added premium for no real reason. MSI's cases are also not great
https://linustechtips.com/topic/1271316-msi-power-supply/#findComment-14229120
Great advice everyone. I really appreciate it. I did look at the PSU tier also just to make sure the MSI brand wasn't listed prior to posting so the fact it was missing was even more of a reason to hold off for now. And I agree at the end of the day an all 1 brand doesn't really matter. Just a situation being my first I just figured personally it would be an interesting way to go. I have an MSI 2060 GPU and an MSI motherboard that I plan on using a 10th gen CPU so I definitely don't plan on going cheap on the power supply but I know high $$$ also doesn't guarantee premium results.
Not going with the best ram or storage means something may go wrong with it but its a cheap fix. Going with a wrong power supply and you can lose your whole rig so just treading carefully on that one. So I'll just take another look at that list and steer clear of the MSI PSU for now.
Thanks again everyone!
https://linustechtips.com/topic/1271316-msi-power-supply/#findComment-14229136
