4pin fan to 3 pin motherboard socket
Solved by WoodenMarker,
What motherboard and fans are you using?
The cable you linked is not a header used for case fans. Make sure you're looking at the correct headers.
Fan headers have a notch to align the pins.聽
聽
Moved to Cooling.
Featured Topics
Rbakker02 路
Posted in General Discussion0 -
BaidDSB 路
Posted in General Discussion2 -
1
Mistr J 路
Posted in Troubleshooting3 -
2
4
2
coolbean28 路
Posted in Graphics Cards8 -
awsomename999 路
Posted in Troubleshooting4 -
RoyTheGeek 路
Posted in Phones and Tablets2
