help Samson G Track Pro not working as expected...
Solved by Ahoy Hoy,
Im going to guess your problem relates to microphone position and possibly your talking volume. The further away the microphone is or the quitter you talk the higher the gain has to be on the microphone to pick you up. High gain means its also picking up more of the background noises eg your keyboard the fan etc. It also means more electronic noise (the hiss you hear in the background)
Get the microphone closer to you and project your voice a bit more and I suspect you may have a few less problems.
All presumption on your positioning and volume if it is right next to your mouth may be broken. USB port shouldn't matter aslong as its getting enough power. So dont have it in a USB splitter.
