Help with adding a component into a simple circuit
I bought a heat gun. it works great. I'm actually surprised how well it works with being so inexpensive.. Let's see how long it lasts.. thats a whole other story.. But the issue is, you plug it in and turn it on.. My only 2 options are off and full blast.. I took apart the case to see what the inside looked like Its a very simple circuit.. 110v ac in, theres a switch, a brushed motor with fan blades attached to it using the body of the heatgun as the path for moving air, and theres what appears to be a cardboard tube with a piece inside that has coiled wire wrapped around it..
I would like to add in whatever i can fit in there that would give me the functionality of turning the fan up and down, and Turning the heat up, down and off. For those who know what theyre doing, what would i need to do here? I would prefer there to be two twisting knobs in the end. One for airflow, one for heat so i can make it gradual however hot or powerful i want.
Also, If this could be as cheap as possible that would be awesome.. If this is gonna cost me 100 bucks in parts then ill just go buy another, better heat gun.
So... you would like to add something like a potentiometer in there to control the voltage that's allowed to go to the components?
Technically, it could be done relatively inexpensively... But unless you know what you're doing, I wouldn't recommend it.
Exactly. But is it as simple as that? Add in a potentiometer to the wires going to the motor, and add another potentiometer on the wires going to the coils? This will be the first time doing anything with 110v. It scares me a little. lol
I mean, it's either that, or go the super jank way and put a light dimmer on the circuit instead. lol
Would probably be easier.
Actually, instead of a potentiometer, might be better to use a variable resistor.
They can technically do the same job, but if there's just two cables, the variable resistor would be preferable.
For the potentiometer to act the way you want, you would have to tie one of its "leg" to the other, which is one extra step where things could go wrong. As such, simply getting a variable resistor in the first place, might be better (a light dimmer is a sort of variable resistor).
Unless you know exactly what you're doing, don't play with the 110VAC side of electronics. Just buy the heatgun that has the features you want/need. The effort really isn't worth the risk of electrocuting yourself or combusting your domicile.
At the level of power being drawn, pretty much any pot would vaporize itself almost instantly. Any energy not being used by the heatgun needs to be dissipated (as, ironically, heat) by the voltage divider (which is dangerous and inefficient). You'd need some sort of AC chopper (like a household dimmer switch) for the heat side, but AC motors may be harder to regulate (if they don't start properly, they'll stall and windings will melt).
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
Yeah thats exactly what im worried about.. Thats a lot of V's and A's in that plug.. Not quite the arduino's and SBC's i'm used to dealing with..
oh actually, thats a good idea.. An in wall type dimmer would be able to handle the power and do exactly what i want.. GREAT idea!! definitely janky but ill take a janky working end result over an electrocution and magic smoke electronics. lol
Well, whether or not it can handle it, that's something I don't know.
A heatgun typically take up 1500W. At 110V, that's nearly 14A. Would the dimmer able to handle it? ... I don't know.
But well, it can be a fun experiment. As an electrical student I would certainly love do to something like that for funsies instead of playing around with motors. What could possibly go wrong, right?
I was picturing the ones that are meant for multiple bulbs and a ceiling fan. I think thatll be able to take the amp draw.. We'll find out anyway. haha. I really wish i could use a few potentiometers tho. That would be perfect.
Potentiometers aren't at all designed for power control. Like it's not even close.
A bulky variable resistor (also known as rheostat) could do the job, but it's a terrible solution as it produces loads of heat and wastes power.
A chopper based circuit of somekind (like a light dimmer) would be best, but chopper based power controllers for very high power loads (such as heatguns) can be expensive.
What I would certainly suggest is that whatever you do, instead of trying to build the power controller into the heatgun, build it as a standalone device with a power outlet on it, that you can then plug the heatgun into. That way you avoid modding the device itself, and you have the added bonus of being able to control the power level of other machines as well (this can be great for all sorts of tools).
The problem is this is all better done at the design stage and built into the product.
Heat control you could have multiple elements, say 2 of the same size and a 3 position switch that switches one or both in for high or low.
The motor can be a type with different windings/poles you can switch between for different speeds.
Much harder to retrofit these sort of things after.
Thats actually a great idea! then i could use it for many things, not just this.. what an awesome idea.. TY!!
