So today Black Ops Cold War came out and apparently its a very gpu intensive game because my gpu gets to 70+c and junction temp 80+c and I never have these temps and i want to lower them
Specs
rx 5700 xt gigabyte gaming oc
ryzen 5 3600
msi x470 gaming plus
ripjaws 2x8gb 3600mhz c16
seasonic 650w
corsair h100i pro xt
https://linustechtips.com/topic/1268708-gpu-running-hot/
those temps are 100% normal and 1000000% acceptable. Junction temps are perfectly fine up to 110c.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1268708-gpu-running-hot/#findComment-14208212
Throw a more agressive fan curve at it if it truly bothers you but those temps are more than fine
Primary Laptop (Gearsy MK4): Ryzen 9 5900HX, Radeon RX 6800M, Radeon Vega 8 Mobile, 24 GB DDR4 2400 Mhz, 512 GB SSD+1TB SSD, 15.6 in 300 Hz IPS display
2021 Asus ROG Strix G15 Advantage Edition
Secondary Laptop (Uni MK2): Ryzen 7 5800HS, Nvidia GTX 1650, Radeon Vega 8 Mobile, 16 GB DDR4 3200 Mhz, 512 GB SSD
2021 Asus ROG Zephyrus G14
Meme Machine (Uni MK1): Shintel Core i5 7200U, Nvidia GT 940MX, 24 GB DDR4 2133 Mhz, 256 GB SSD+500GB HDD, 15.6 in TN Display
2016 Acer Aspire E5 575
Retired Laptop (Gearsy MK2): Ryzen 5 2500U, Radeon Vega 8 Mobile, 12 GB 2400 Mhz DDR4, 256 GB NVME SSD, 15.6" 1080p IPS Touchscreen
2017 HP Envy X360 15z (Ryzen)
PC (Gearsy): A6 3650, HD 6530D , 8 GB 1600 Mhz Kingston DDR3, Some Random Mobo Lol, EVGA 450W BT PSU, Stock Cooler, 128 GB Kingston SSD, 1 TB WD Blue 7200 RPM
HP P7 1234 (Yes It's Actually Called That)  RIP
Also im happy to answer any Ryzen Mobile questions if anyone is interested!
https://linustechtips.com/topic/1268708-gpu-running-hot/#findComment-14208227
23 minutes ago, OBsnacks said:
Yea but us their a way to get slightly cooler like 5c
crank the fans to 100% maybe? but realistically, no.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1268708-gpu-running-hot/#findComment-14208289
2 minutes ago, OBsnacks said:
is their somekind of undervolt to reduce junction temps
there is no need. Your temps are 100000000% within spec and great actually. You're being paranoid over nothing.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1268708-gpu-running-hot/#findComment-14208614
Better cooling in the case could help.
The game isn’t any more gpu bound that almost any other game.
https://linustechtips.com/topic/1268708-gpu-running-hot/#findComment-14208931
6 hours ago, OBsnacks said:
I have a fan in every location in my pc
That doesn’t really mean much.
https://linustechtips.com/topic/1268708-gpu-running-hot/#findComment-14210122
