sounds like a dead mobo, welcome to the world of the shit b450-f
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1268363-big-problem/#findComment-14205507
Just now, Deanmurtagh said:
Thanks bro real disappointing any recommendations on a diff motherboard
I'd get a b550 pro, or elite from gigabyte, if you have a spare gpu try that, is the motherboard outputing an error led?
AMD blackout rig
https://linustechtips.com/topic/1268363-big-problem/#findComment-14205517
Doesnt look like theres any error leds how do i know its not like a dead gpu?
you could test with another GPU, or another mobo, if you have one.
AMD blackout rig
https://linustechtips.com/topic/1268363-big-problem/#findComment-14205550
2 minutes ago, Deanmurtagh said:
I mean my friend is over helping me and his rtx 2060 ko gaming works i could try that
try it, if it still doesnt work, if it doesnt boot its likely your mobo
AMD blackout rig
https://linustechtips.com/topic/1268363-big-problem/#findComment-14205566
Yep no boot or display or anything think its the mobo
in that case i think it would be the mobo too
AMD blackout rig
https://linustechtips.com/topic/1268363-big-problem/#findComment-14205611
