1 minute ago, forecaster1310 said:
It's supposed to show more suggestions but it deosn't.
Are you sure you made a project using the language you need to use?
https://linustechtips.com/topic/1267866-vs-code-problem/#findComment-14200856
restart vscode should fix it.
or reinstall the plugins.
https://linustechtips.com/topic/1267866-vs-code-problem/#findComment-14200959
1 hour ago, forecaster1310 said:
that doesn't work either😢
have you installed all the extensions?
https://code.visualstudio.com/Docs/languages/csharp
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/1267866-vs-code-problem/#findComment-14201702
