My First Gaming PC build from
 an AMD Athlon 3000G
 an 8GB DDR4-3000 dual channel kit
 an MSI B450M PRO-VDH
 Corsair VS 450W on
 a Deepcool MATREXX 30
 a Seagate Firecuda
and i picked a msi geforce gtx 1050 ti graphics card and its laggy still i dont know whats going on im new new to pcs im not sure what i need to upgrade or if i did something in the settings
https://linustechtips.com/topic/1267673-pc-build-help/
24 minutes ago, X420snowgodX said:
laggy
there is a difference between lag and fps drop.
what is your fps in your game and which game are you playing?
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1267673-pc-build-help/#findComment-14199596
16 minutes ago, X420snowgodX said:
im playing fortnite and when i turn really fast my screen skips frames i freeze some times i get 20 frames if i turn too fast and i have a 144 hz monitor as well
Quote people so they can see your reply.
As for your issue have you plugged in your monitor cable into the GPU or mobo? Make sure its plugged into the GPU.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
https://linustechtips.com/topic/1267673-pc-build-help/#findComment-14199674
thanks for letting me know of op reply!
settings?
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1267673-pc-build-help/#findComment-14199694
1 hour ago, X420snowgodX said:
im also using a 144hz monitor i can run a smooth 60 fps but i want more
what would i need to upgrade aslo my cpu isnt overclocked yet
if you are running high refresh rate but you can't hit the target refresh rate, try to lower your monitors refresh rate. if you want to upgrade, your cpu would be a excellent choice. if you don't have too much money, a r5 3600 should fit well. anything higher and your gpu might bottleneck
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1267673-pc-build-help/#findComment-14202116
im getting 16 gig ram as well for streaming im running two slots of 8 ddr4
https://linustechtips.com/topic/1267673-pc-build-help/#findComment-14202122
that would be wise.
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1267673-pc-build-help/#findComment-14202128
2 hours ago, X420snowgodX said:
that r5 3600 CPU could i get a slightly better gpu to match it because my gtx 1050 ti only gives me 60 fps
A 1650 super could be a good upgrade without spending to much money.  If you paired a r5 3600 with a 1650 super you could probably get around 50% or more performance depending on what game you're playing.
https://linustechtips.com/topic/1267673-pc-build-help/#findComment-14202516
i have 3000 hz ram would a 3200 ram be a problem
are you mixing and matching? its always best to have the same kit but you would try to dial in similar settings by either overclocking or downclocking one of the kits
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1267673-pc-build-help/#findComment-14205700
  • 2 weeks later...
i got the r5 3600xt hoping that isn't too much of a jump from the r5 3600 or a need to upgrade my gtx 1050 ti gpu
https://linustechtips.com/topic/1267673-pc-build-help/#findComment-14245546
you are going to want an upgrade
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1267673-pc-build-help/#findComment-14245587
