Need help accessing my router.
Solved by WereCatf,
36 minutes ago, avan_ said:Recently bought a Cat8 cable and switched from WiFi to Wired connection.
Everything went well until I try accessing my router to port forward. I thought it would've been like how I access my router with WiFi but seems really different.
I tried accessing with the default gateway didn't work also the DHCP server.
No idea why they start with 221.127
That's not an internal IP-address, that's a public, Internet-facing IP-address. You either plugged the Ethernet-cable into your modem, not your router, or your router is configured to bridge the Ethernet-ports directly to WAN.
