Stupid multi GPU&Monitor questions
Woltox
Heyall
Been thinking of this for a while.
Im running atm 2x monitors (1080p), where 1 monitor is for gaming and other is for socials like discord/spotify.
If I am to run each screen off different GPUs are there fps to gain from that (example using my prev generation GPU on my second monitor) ?
Anyhow thanks for the future response :D
In SLI or Crossfire only card has active Display Outputs (mostly the top one)
if there a seperated you have to figured that out by useself PS: PhysX is not a good idee ^^
